Ceiling aligned to sloped beam
ms64674
Observer Observer
ms64674
Observer
Observer
Hello everyone,
I hope you are all doing fine. My question is pretty straight forward, I want to put ceiling on my sloped beams as shown in the image below. I tried creating a floor and then picking supports, but I was wondering if there is any other simpler / easier way to deal with it for ceilings since I am having slight problems here and there with that method.
kadmonkee
create a reference plane for each part of the ceiling to align with the sloped beam in section view , name them accordingly
sketch the ceiling based on one ref planes work plane, if the option is available select defines slope as if it was a roof or sloped floor. repeat the steps for the other part of your ceiling if needed.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
You can add slope arrows to define the head/tail elevation or slope to match the beam.
Got full Revit?   If so, another approach would be to use a Floor or Roof + Modify Sub Elements.
