Cavity door OTB show door leaf not full frame size
wisedrawing
wisedrawing
anyone have an idea for Revit OTB cavity door family how to get it to show the door leaf size rather than the full width of the cavity framing??
Revit doesn't have a "Cavity" Door in my OOTB Content Library.   Post the one you are working with here so we can see what you need to do.
FWIW:
If the door leaf width is controlled via a Parameter that is not an available Label in the Tag Family, you can open the Family and make that door leaf width parameter a Shared Parameter. Then you can load that door width Shared Parameter into the Tag Family.
If the door leaf is a nested family and is Shared, you could TAB-Select it to Tag it separately.
That can be easily added to a door family (if you need to tag) or a door schedule.
wisedrawing
brilliant work thanks, I have had that cavity door in for so long I forgot that I found it somewhere else bathbradley, with both your inputs here I just went back to the family, and into family types, and found the door width which had a formula that added multiplication of the door size and then some additional width - so I deleted that bit of type and its fixed - thanks heaps
