Casework Labels Not Working
Ed_Cormier
Message 1 of 22
Ed_Cormier
I'm trying to add nested labels into casework families with work-plane based enabled. When loading into a project model group, we get an error message to fix groups when mirroring. This process works for plumbing and appliance families, why doesn't it work for casework families?
Replies (21)
Message 2 of 22
syman2000
Is the casework hosted on wall? If yes, it will impact the family. It will work if the family is set to non-hosted or the host wall is in the group.
Message 3 of 22
Ed_Cormier
The family is a base cabinet family which is floor hosted.
Message 4 of 22
syman2000
If the floor is not inside the group, this is where you will see fix group message. Group is very picky. Often you have better success with non-hosted object within groups.
Message 5 of 22
Ed_Cormier
The problem is as follows:
Work Plane-Based option enabled with labels inserted on work plane = Error
Work Plane-Based option enabled without labels inserted on work plane = No error
Work Plane-Based option off with labels inserted on work plane = No error
The confusing thing is that the problem is isolated to casework families. Plumbing and Specialty families setup the exact same way works just fine. I was hoping to avoid having to recreate all our casework families as plane based families.
Message 6 of 22
syman2000
Can you provide sample group with the casework? I like to test and see if there are other way to edit the family without destroying the group.
Message 7 of 22
Ed_Cormier
Attached is the Revit File with the Group in question. We get the error message while trying to mirror the group.
Message 8 of 22
What is the purpose of checking Workplane in the casework families?  Are you going to place some upside down, or vertically, or on a slope?
Message 9 of 22
Ed_Cormier
With the type of projects we do, we often have varying floor construction. When copying unit groups up to a level with a different floor type, we often see the families hosted to the original floor stay at that level...hence getting the message that identical instances are in the same place. Plane-Based families avoids this issue.
Message 10 of 22
Mirror?  You can't even place an Instance of the Group, much less Mirror it.
Message 11 of 22
Ed_Cormier
For troubleshooting, I've deleted all the casework from the group and then work with trying to place a single cabinet.
Message 12 of 22
Why not just fix the Group and then make a two Groups - one a mirror of the other?
Message 13 of 22
Ed_Cormier
Because of Client changes occurring often. We don't want have to make changes twice.
Message 14 of 22
Ed_Cormier
We have a manual solution that uses multi-category tags keyed to type comments. So, with that being said, we've got to move on, unless there's an actual solution/ workaround.
Message 15 of 22
Changes?  Are you even able to place an Instance of this Group? The darn thing is blowing up on me.  Seems to me that would be the priority.   That is, getting one to work right first, rather than figuring out how to best handle future possible changes to the Group/configuration.
Message 16 of 22
Ed_Cormier
As I've stated, we need to move on. Thanks for your efforts. On another note, if you still want to work on it, I've attached the same file with all the casework removed from the group. This will not blowup on you. You can then try to add one of the cabinets with the labels and see what our issues are.
Message 17 of 22
syman2000
I manage to look at what is wrong. I would check off these in the cabinet families.
Also you have constraints built into the group. This will cause it to break.
Message 18 of 22
Ed_Cormier
I know about this solution. This is stated in message 5 in this chain. By turning the feature off, we're forced to host them to the floor and run into issues when copying them up to a level with a different floor type.
Message 19 of 22
syman2000
This is a tradeoff. If you want it to mirror properly, then that workplane need to turn off unless it is hosted on something and that something is part of the group. Right now that workplane casework is host to nothing. When you mirror, Revit doesn't know what that casework host when it mirror and it force you to create new group.
Message 20 of 22
Ed_Cormier
That's not correct, because without the label everything works. It's only when the label is nested into the casework family that Revit has the issue.
