Cant see Walls -Plan view (columns are visible ) lost ..
jkp123
Message 1 of 15
jkp123
Hello there ,
i tried everything i can from material to view range to surfing the internet for hours.
those walls wont be seen in my plan view ("קומת קרקע") but are seen in 3d view
note that the columns are visible
adding the .rvt here,
any help will appreciate
Replies (14)
Message 2 of 15
What walls? There are none.
Message 3 of 15
dferreira-blackwell
no walls in 3d brother.
Message 4 of 15
jkp123
how can it be ?
i check again ... look , i see those walls in 3d...
i double checked , i downloaded the file i uploaded ...
see screenshot
Message 5 of 15
dferreira-blackwell
nothinghere brother
Annotation 2019-07-25 194224.png.
Message 6 of 15
Contact Sofistik.
Message 7 of 15
jkp123
i dont know ... maybe this walls are currupted or something ... i still see them
look same view like you (but for some reason i cant select all elements in the view)
Message 8 of 15
Here they are.
They are non-structural walls so they do not show on your structural plans.  Change the views to Coordination or check Structural box for the walls
Message 9 of 15
dferreira-blackwell
Message 10 of 15
Alright @ToanDN , I give up. You get big Brownie Button. Care to share?
Message 11 of 15
jkp123
yes!!!
TY man this is it!
Edit :
well it works in Floor plan , but when i change to structural plan it doesnt work .. i still cant see them even
with the structural checkbox.
Message 12 of 15
What is the view name?
Fix your view range.
Message 13 of 15
I can find then and copy them to new project, but I can't see them in OPs Project.  I must be f*cking losing it!
Message 14 of 15
FOUND THEM!!!
@ToanDN: did you just copy the OPs picture?  Funny.  You had me going.
@jkp123: I toggled the wall's "Structural" parameter on and off, and Voila! they appeared.
Message 15 of 15
Don't know about the OP, but you get a solution credit from me.  I'm embarrassed.
