Cant manipulate revit linked models
Hi, i recently upgrade myself from revit 2016 to revit 2018. I´m working on several projects in order to link them in one at the end, but when i try to link one model to another it inserts itself but i cant manipulate it inside the home model. I cant even select it for a rotation or move it from the insert position. Does anyone knows whats might be happening?
Sahay_R
Check to see if your linked model has been pinned. Unpin and you should be fine.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
It doesn´t even appear the pinned option.
aghis_no
On the bottom right of the" application window" check if the "select links" option is active (a small icon with an selection arrow and a chain).
This lets you turn on or off the links selection and manipulation.
hope it helps
THANK YOU!!!!! this was my solution
Sahay_R
1) Are you able to select the link?
2) If not, make sure that you have Select Links checked
3) Once you have the link selected, you should be able to see the pin options under modify
4) If not - make sure the link is not on a Non-Editable Workset
4) Check the coordinates in the Properties of the link. This is what they should look like
Having the lower option selected will prevent you from manipulating the linked file.
Rina Sahay
Palmer413
This did not work for me, any other suggestions?
