Cant import rvt model into client's revit template.
Message 1 of 35
Got thrown in the middle of this. So I'm currently taking a hotel model that was drawn in 2009 revit, I don't know why, I'm tasked with upgrading this model to 2022 and then importing the finished model into a client's template.
I can't get this done, and I need someone to help walk me through it. I can't group the project, and doing it by floors is impossible as when I break it up it creates more issues. So I feel like I'm stuck trying to link bind this model but it just seems like 3 hours to complete this process is too long. Whenever I have been successful on the link bind the silly wall sweep error comes up and it won't give me an option to delete or anything. But I don't want to gut this drawing just to get it to work. HELP.
Replies (34)
Message 2 of 35
syman2000
Why not do the other way where you import project standard from the client template into the upgraded model?
Message 3 of 35
I'll give that a go. That will transfer all elements on their template?
Message 4 of 35
For now, I can link, but when I go to bind it gets to 100% but SEEMS to stop there at processing:extending changes to group, but stays on this step for hours.
Message 5 of 35
That doesn't seem to work.
Message 6 of 35
Can you open the 2009 model in Revit 2022 with Audit option checked and let Revit upgrade it?  And you mentioned binding link, where does that step come from?
Message 7 of 35
I didn't do the audit option, I have to bind this linked into their worksheet document so the architects can make there changes. So simply linking it won't work, I have to have a workable model in their template
Message 8 of 35
I have to link bind this into their worksheet doc*
Message 9 of 35
Workshared, autocorrect
Message 10 of 35
Now I'm trying to load it as a group.... hopefully this works, but I'll try auditing next.
Message 11 of 35
There seem to be two problems:
1. Upgrading a model from 2009 to 2022
2. Bring the upgraded model to the architect's template
I can see that you are still stuck at (2), but can you clarify if you have successfully done with (1)?
Message 12 of 35
I was successful with the upgrade, I can not for the life of me upload into their template.
Message 13 of 35
Whenever I get close to being successful on the upload it simply states 2 errors involving wall sweeps and then doesn't allow me to finish as they MUST be corrected(says who). I've tried doing it floor by floor, and 2 floors have this problem. I tried link binding, I even tried copy and paste. Is there not a cut dry way to do this? Haha
Message 14 of 35
- open the upgraded model and the template in the same Revit session
- set the model as the current working window and run Transfer Project Standards
Does it not work?
Message 15 of 35
I tried that, but I'm guessing since it is a workshare document they gave me I can't simply upload their info or assign their template as mine for the model
Message 16 of 35
Workshared or not is not an issue?  What errors are you getting?
Message 17 of 35
I don't understand the gymnastics. Why don't you just hand over the 2022 to the client?  Or are you supposed to go through Project and change Family Types, Line weights, Materials, View Templates, Object styles, Annotation styles, Color Fill Schemes, Fill Patterns, Print settings, etc., etc., etc.?  Basically anything and everything  in the Project that deviates from the client's own standards?
Message 18 of 35
They're unable to because of these errors, so I'm trying to correct it for them and get it uploaded
Message 19 of 35
They get these errors
Message 20 of 35
2 errors??? That's all?  Heck, go have a beer to celebrate!
