Cant get stairs to connect 2nd floor
BBV90
Message 1 of 16
BBV90
Hello everyone,
Trying to model a spiral stairs with but theres a gap between my second floor and the stairs. The levels are on the file. Image attached. What do I have to arrange to adjust the height of the stair so it connects to the second floor ? Need 36 steps with min 170 mm risers
Replies (15)
Message 2 of 16
Yien_Chao
i think the problem is from the profile... try to make another one.
Message 3 of 16
BBV90
need to have 36 steps risers to be min of 170 max to 180. It still didnt work
Message 4 of 16
There is nothing wrong with stairs.
If you don't want the end Riser, then edit Stair and deselect "End with Riser".
Message 5 of 16
BBV90
It is not touching the second floor. and I need 36 steps with min 170 mm - 180 max riser
Message 6 of 16
BBV90
now it is touching but risers are below min. How can I adjust that
Message 7 of 16
I understand what you are saying, but your stairs are absolutely correct. If you want to "End with Tread" then you need an extra Tread.
Message 8 of 16
Do you want Revit to calculate Riser Height, or do you want to calculate Riser Height?
Message 9 of 16
BBV90
I just need to adjust the height of riser to be min 170 manually, is there a away for that
Message 10 of 16
BBV90
 guess i want to calculate Riser Height
Message 11 of 16
It is.  Obviously, you are not happy. What would make you happy?
Message 12 of 16
BBV90
I just need to adjust the height of riser to be min 170 manually, is there a away for that.Im confuse sorry if there's miscommunication
Message 13 of 16
Reduce the number of Risers then.
...this is what you want; right?
...you can't have your cake and eat it too.  36 Risers won't work if you want to maintain a Riser Height of around 170.
Message 14 of 16
Nothing is wrong with your stair. It reaches the level but the top tread isn't there because the run is End with riser.
Normally the floor will be at the top but if you want the top tread to level with the floor then untick End with riser and add grip stretch the top dot of the run to add one more step.  Or sketch a top landing if you don't like the support to extend farther.
Message 15 of 16
BBV90
thank you
Message 16 of 16
BBV90
thank you
