Cant Collaborate in the cloud in Revit 2018 but I can in 2019
cgambleTFFSQ
Message 1 of 11
cgambleTFFSQ
Why would I not be able to collaborate in the cloud in Revit 2018, but I can in Revit 2019.
When I try to collaborate in 2018 I receive this access denied message. Are separate licenses applied to each year edition of the application, like I need a 2018 license and a separate 2019 license?
Replies (10)
Message 2 of 11
Do you just renew and switch your license type?
Message 3 of 11
cgambleTFFSQ
I don't think so, however, with working from home, I vpn in to get to my revit license to open revit 2018, and if I don't vpn in I get this message.
But I don't think this would have anything to do with collaborating in the cloud. I have a bim 360 license, does it only apply to 2019?
Message 4 of 11
Samantha-G
Be sure you have the most recent update for 2018. I believe it needs to be 2018.3.
Sam G, CM-BIM
Revit Certified Professional
Message 5 of 11
cgambleTFFSQ
I have 2018.0.0.420
Message 6 of 11
Samantha-G
You will need to update your Revit then.
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
Sam G, CM-BIM
Message 7 of 11
cgambleTFFSQ
Okay I will look into that. Has that been the resolution for you before?
Message 8 of 11
Samantha-G
I have not, but I know for a fact the software has to be up to date.
Sam G, CM-BIM
Message 9 of 11
cgambleTFFSQ
 Okay, I hope this fixes it, I'm not too confident though because you can have earlier updates of the application and still collab in the cloud, you wouldnt lose your license or not be able to find it, as far as I know.
Message 10 of 11
Samantha-G
Please see the link below:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Sam G, CM-BIM
Message 11 of 11
cgambleTFFSQ
That was it, thank you so much!
