Greetings Autodesk & Community,
My work recently gave me a new Laptop as my old one was getting too slow.
Today I went to create a drawing for a project for one of our Clients, and while inside my elevations on the drawing, I noticed that I cannot select the walls that I added. There are some shown in elevation view that I can see the edge of, and also some at the sides that are in section and are cut through.
Now, I have created hundreds of these drawings and never ran into this issue before.
So my thought was that, something got changes when I installed Revit 2023 (the old stores I created were in 2023 as well).
I did some digging and googling trying to find a solution, and can confirm that the walls are NOT pinned (even if they were, I have "select Pinned Elements" turned on), and I do not use the 'Design Options' and everything is in the Main Model.
Attached is a screenshot showing what I am talking about.
I clicked at the top right, and dragged down and to the left.
You can see my crossing selection window is highlighting all of the objects in the view except the Wall I am crossing (and the family object inserted on that wall).
Any suggestions on why I cannot select these walls?
As another test, I opened a project I had completed a few months ago on my old Laptop, and the walls are also not selectable, but they used to be selectable on my old machine (again, running the same version of Revit).
Thoughts?
Thank you,
Morgan
