Cannot see project parameters in properties pallet
Yesterday I created shared parameter "Task ID"  and assigned it to project. But now I can see the " Task ID" in project parameter dialog box and cannot see it in properties pallet under construction which I did see before.
When I tried to assign it gain it says the parameter is already assign.
How do I see it in properties pallet?
Ahmed_M_Heteba
you should choose an element which is assigned to it i didn't see it in your screen shots
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
hmunsell
what are you assigning the Parameter for? is it a View, Sheet, modeled element, etc...?
i assume you got the TaskID from a shard parameter file?
For screenshot 67, ONLY CHECK the category you wan the parameter to appear in.
  • Check All is seldom ever needed.
  • if you want this to apply to all walls, check wall, etc...
Howard Munsell
