Cannot Re-install Revit
jomarc700
jomarc700
I uninstalled Revit to re-install so that dynamo would run properly but
when i was trying to re-install it says its already installed.
Hoping someone helps!
Jomarc E. Baquiran
CAD Evangelist
YouTube
Facebook | LinkedIn
bin
I had this exact problem not long ago, I used CCleaner but it didn't help much. Then I searched Autodesk in my C drive and delete all those folders, I also downloaded the whole Revit installer (15.xGB) and finally installed it successfully.
DarrenP
go through this: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
DarrenP
jomarc700
Thanks!
Done with that.
I'm checking https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
now.
Any idea what is the product name and product ID for Revit 2020?
Jomarc E. Baquiran
CAD Evangelist
YouTube
Facebook | LinkedIn
jomarc700
Thank you all.
Managed to reinstall Revit but my true problem with Dynamo still exists.
The grid is still parallel to my view.
The reason i installed and reinstalled Revit is to fix this.
Jomarc E. Baquiran
CAD Evangelist
YouTube
Facebook | LinkedIn
bin
Did you just rotated to a top view?
