Cannot print multiple sheets at once
I cannot select view/sheets in the print menu. It will not let me print multiple pages at once, I have to open each sheet I want to print and then print. It just will now let me click on any options. So frustrating. I have closed Revit and reopened it but nothing has changed, this has been going on since I downloaded 2018.
you can see on the image I attached, it will not let me click on any options.
Do not use Microsoft PDF printer.  Go to Windows printer settings and choose another PDF printer as the default one.  This question must be asked over twenty times here.
That was the first thing I tried to switch, and AdobePDF does the same thing. Do you have another pdf system to recommend...
Did you switch the printer within Revit or via Windows printer settings?  Do it via Windows settings.
None of the PDF printers I have tried (Adobe, Bluebeam, PDF Creator, PDF Architect) has this problem.  Only Microsoft PDF does.
