Cannot open Revit: Missing Schema Folder
Annotation 2021-01-29 151327.pngAnnotation 2021-01-29 151237.pngI have successfully downloaded all the Revit products (for Revit 2021), but when I try to open Revit, I am met with the following message: Missing Schema Folder.
I have tried to repair and reinstall but I still have the same problem. I also do not have access to a working Revit to replace the schema folder.
What should I do?
Nvm. I found the solution.
If it's alright with you, I'll leave the solution up for others to see.  Or do you want me to remove it from your thread? Let me know ASAP.
You can leave it up!
ahmadfiroozi000
I had this problem, one of your hardware is poor, so Revit can't open, you better install the old version for example 2019
ozkanruveyda92
Community Visitor
Community Visitor
nasıl buldun
