Hello and Thank you
Recently is not opened One of my project. apparent the below error :
Attached my Revit file:
I studied here:
But, i don't have Journals file
Gelöst! Gehe zur Lösung
Gelöst von Matt__W. Gehe zur Lösung
are you trying to open in 2015 or are you upgrading to a new version?
DarrenP
No . Unfortunately,because I do not have the 2015 version.
it looks like this file came from Revit 2016 which it does open fine in revit 2016 does not open in 2017 or 2018 already tried audit in both versions same error pops up
i tried doing this: http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-9AFAAE6B-4107-4478-8B80-53467FE118DB
but cannot seem to find any of the elements listed in the journal
DarrenP
@GHASEM_ARIYANI below is a link to the model in 2017 format. I had to delete a corrupt family (Generic Models - ET People Couple) to get it to upgrade to 2017. If you have a clean copy of that family, you can load it into the original model and overwrite the existing and it should clear up the corruption within the model, allowing you to upgrade to 2017 without losing any content.
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Thank you
Yes. before I tested and failed.
thank you.
The file opened.
If possible, can you describe the repair methods.
I mean, is this ,How did you open To fix.
@GHASEM_ARIYANI, it's actually quite simple. In my experience dealing with models that either won't upgrade, you can't purge or audit, or crash when editing certain families/views/sheets, it's due to a corrupt family or families.
Here's what I do to troubleshoot which family/families is causing the problem.
1. Open the model.
2. Save out the families to a temporary location that can be deleted (you don't want to overwrite any company standard families with potentially corrupt ones). When Revit finds one that's corrupt, it will crash or throw up an error message.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
3. Make note of the family that crashed Revit.
4. Close Revit.
5. Reopen Revit.
6. Open the model from step 1.
7. Reload and overwrite the corrupt family from step 3 using a clean copy from a company directory of standards, for example.
8. Save the model.
9. Repeat steps 2-8.
10. Wash-rinse-repeat until Revit doesn't crash while saving the families.
That's it! ![]()
Matt Wunch
Twitter | LinkedIn
thank you
I know steps 1 to 10 ,But,I asked how you open corrupt file?
It opened just fine for me in 2016.
Matt Wunch
Twitter | LinkedIn
Make sure you have all of the latest updates for Revit installed.
https://knowledge.autodesk.com/support/revit-products/downloads
Matt Wunch
Twitter | LinkedIn
Hello and very thank you
