Cannot Open Model to Relinquish Elements
My team and I are having a lot of trouble trying to resolve and issue with relinquishing elements in Revit. There seems to be a continuous loop between two partners and the central model. When User1 attempts to open the model, they receive the message "Can't edit the element until 'User2' resaves the element to central and relinquishes it and you Reload Latest. When User2 attempts to open the model, they receive the message "Can't edit the element until 'User1' resaves the element to central and relinquishes it and you Reload Latest. \
Neither user is able to open the model to relinquish the elemets.
Is thert anyway to resolve this issue without breaking the link the the central model?
And what would cause this issue?
Any help/direction would be gretaly appreciated.
Aaron.Lu
Dear kmb5903,
  this should be a Revit issue rather than RevitAPI, am I correct? if so, we will move it to the Revit forum, since you will get more quicker and proper answer there for Revit questions 🙂
Below is just for your reference
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture:
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
(This may include platform product usage questions)
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
thanks.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
mikako_harada
Hi Kmb5903,
I'm moving to Revit product forum.
Mikako Harada
jessica.donnellyVVYCM
Observer
Observer
Did this ever get solved? Having the same thing happen today and its a nightmare
