cannot join walls that were edited
uedaCZDVD
uedaCZDVD
I have this case where I have 3 walls in different angles with different triangular shapes. The only way to achieve the shape of the wall is by editing and cutting it. Once I do that, I am not able to join the walls and miter them to show clean on elevations or 3D views. Any thoughts?
akshay_surveKTDLP
@uedaCZDVD Thanks for reaching out on Autodesk Forum.
It would be more helpful if you could share a sample Revit file with 3 walls in different angles with different triangular shapes. This will help us to analyze and test the possibilities in Revit 2023 and above versions.
 Looking forward to hearing from you!
Akshay Surve
Autodesk | Technical Support Specialist
uedaCZDVD
Thank you for your response!
I have attached the .rvt file will the 3 walls that will not join.
akshay_surveKTDLP
@uedaCZDVD,
Thanks for showing great patience during this troubleshooting process.
Here is my suggestion: Try to reset profile of the wall and edit profile again, then the walls can join properly.
Please let me know if this information helped with your request on Forum.
Akshay Surve
