- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I made a light fixture - a screen on a bracket that hangs from the ceiling. I am trying to give the screen portion a tilt parameter. However, when I attempt to host my light fixture to the reference line associated with the tilt parameter, it would not be oriented correctly and I couldn't rotate it ("front" elevation was portrait when I needed landscape). It's a nested family. I tried to rotate the light fixture in its own family and load it back in, and now I can't select any reference line to host it to. Or I'll host it and then changing the tilt angle will throw up an error. Like the reference line and family will rotate independently even though it's hosted AND aligned and locked.
Also if I change the angle to 0 degrees and then back to something else, it loses association with the rotation center and screws up again.
It's driving me mad! Any advice appreciated! Attached model is in 2019. I reverted all changes back so the screen family is modeled in the correct orientation and the "tilt" family is not hosted to the parametric line.
