Cannot host elements to certain stair landings.
MattKincaid
Message 1 of 21
MattKincaid
I have a Revit project with 2 stair cases.  One stair case allows face-based families to be hosted to the landings.  The other stair case does not.  I can't figure out why not.
The 2nd stair case does allow elements to be hosted to the steps. Just not the landing (get the "no smoking sign" when mousing over the landings).  See video, linked below.
https://www.screencast.com/t/LVU2UfAx
Anyone know what the problem is?  I attached the file.  Revit 2019.
Thanks!
Replies (20)
Message 2 of 21
When placing the element, choose Place on Work Plane, then Pick from the Placement plane list, then pick the top of the landing.
Message 3 of 21
MattKincaid
@ToanDN Thanks for the reply, but I guess I'm not following.  I don't see an option in that dropdown to host to the stair landing.  See attached screen shot for the options I do have (none of which seem like what I need).
What am I missing? Thanks!
Message 4 of 21
Choose "Pick" from that list.
Message 5 of 21
Odd. I don't know what's going on.  It's not right, though.
Message 6 of 21
MattKincaid
@ToanDNDoesn't seem to work... I still don't have the ability to host to the landing when choosing that option.
Message 7 of 21
Okay here are the steps, follow carefully:
- Start placing the generic model
- Use button Place on Work Plane on Ribbon
- Click on the box next to Placement Plane to get the drop down list
- Choose Pick.. at the very bottom of the list
- Choose Pick a plane from the next dialog
- Pick the stair landing
Message 8 of 21
MattKincaid
@ToanDNThanks for the detail.  I think that's what I'm doing.  See video linked below.  Am I missing a step?
https://www.screencast.com/t/EY18wepUa
I can place family on the steps using this method.  But still no luck with the landings.
Is it working for you?  Looked like you had the model up in your last screen shot.  Appreciate the assistance.
Message 9 of 21
But the problem is not hosting it to a Work Plane -- it's hosting it to a FACE. So it will move with the FACE it's hosted to.
Message 10 of 21
Of course, it is working for me, hence the screenshots.  Screencast below:
https://knowledge.autodesk.com/community/screencast/c0210af0-860b-4d95-a143-6bddd182ad33
Message 11 of 21
it will move with the face when placed using On Work Plane and pick the face.
Message 12 of 21
It doesn't Host to the FACE that way -- it hosts to the WORK PLANE which is associated with the top of the Landing.   As soon as you move the Landing, the Element become disassociated.  It does not move with Landing.
Message 13 of 21
Move the stairs in this file and see.
https://knowledge.autodesk.com/community/screencast/92648b0b-f0fd-4672-acaa-bde4aee5570e
Screencast will be displayed here after you click Post.
Message 14 of 21
I did dude. I'd post a screenshot to prove it, but unfortunately this Forum is struggling mightily today.  It's a pain in the ass just posting a regular comment/reply.    I'm not even sure this one will go through.
Message 15 of 21
The family moves along with the stairs just fine here as seen in the last screencast. You probably did something to it if it wasn't working for you
Message 16 of 21
MattKincaid
@barthbradleyYep correct : (. It almost works.  But moving the stairs breaks the association.
I'm mainly wondering why the 2 stair cases behave differently.  They seem to be modeled similarly.
Message 17 of 21
Me?!  It's already broken! Clearly.  Something is wrong.  AND, you shouldn't need to jump through all those fricking hoops either.  Just place the **** thing on a Face and move on.
Message 18 of 21
Try this file.  I have fixed the stairs so now you can place on face directly.
Message 19 of 21
MattKincaid
@ToanDNYep  that works.  Thanks.  What did you do to fix the stairs?
Message 20 of 21
Edit the stairs, cut and paste the bottom landing in place.
