- Mute
- Permalink
- Report
I'm working my second project and I'm running into the same issue that I was never able to solve.
I'm using Revit tutorials and they go from Area Plans to having Rooms annotated. There is no in between that shows how you can go from the Area Plan boundaries to having room and room boundaries tagged.
I am guessing maybe I should have had my rooms mapped out first. That is what I was trying to do but the tutorials like I said are ordered teaching area plan first and rooms are just by themselves in a different, separate stand alone module so I'm confused.
For troubleshooting I changed the VG Overrides to show Area Bases, Areas, Rooms, Room Tags. I changed this back and forth in object styles. I've turned off the template. I restarted Revit. Nothing. For a moment I had a random room tag. I deleted it and now I can't see them again. I don't believe I did anything with the aforementioned settings before this happened.
My objective is to not have to map the area plan all over again if I don't have to and to use those boundary lines to make rooms. Or to at least see the rooms in a floor plan - I can't even redraw them at this point if I want to.
Please help me. Sharing the file.
