Cannot edit file not acess to onliine file
stankaye
stankaye
I have a local file but cannot edit due the ccentral model not being accessable--how to disable that ?
You need to open the file from Revit and click the Detach from Central button.
FYI...if the central is not accessible at all, you will not be able to update the central model.  This will create a totally separate model.
Helps to know your situation.
stankaye
Do I have to do that each time---can I make it behave that way all the time ?
Once you save, it creates a new central file.  After that you create a local file from the new central.  If you just want to open the file itself and nobody else needs access you can turn off worksharing.
stankaye
That's what I'm looking for. Where is work sharing turned off ?
Stan Kaye, President & Principal
SKDesign and Consulting L.L.C.
1045 NW 89th Drive
Gainesville, Florida 32606
[email protected]
www.skdllc.com
When you detach it will give you the option to keep worksets or to remove them.  Select remove them if you don't want a central model.
