Cannot decal an image on TV
Hello Friends
I am trying to decal an image on TV. The image is in JPEG format, but in rendering I cannot see the image on TV
I am following this method step by step http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-AE12D8E6-E59D-4981-8842-04E772A63AAC
Please help me, How can I overcome this issue and see my image on TV set.
Your Aarundh
constantin.stroescu
did you make the rendering in your computer or in cloud?
Rendering decals in cloud had some problems before but they were overcome...
Can you post an excerpt of your file?
Constantin Stroescu
Made the renderings in computer.....attaching a file have a look that I get after rendering
constantin.stroescu
I think I was not clear enough....I mean , an excerpt from the .rvt file....
Constantin Stroescu
@Anonymous The trick is to use a material, not a decal, and use a model pattern to space perfectly on the edges of the monitor and align the image to be spaced in between the pattern in the image alignment.
So you may have different materials for different monitors & TV's. (different sizes)
