Cannot change toposolid contour appearance
sascari
sascari
Nothing I do (whether it's visibility graphics or object styles) will change the toposolid contour appearance. What am I missing? It seems no matter what I change, they stay the same as solid lines. I've tried: Object Styles, Visibility Graphics, Object Overrides, Phases. Nothing is altering the look. Why?
kostask_oionei
I have not this issue:
Check the contours subcategory. Select Toposolid - Edit Type - Contour Display - Edit... Maybe the Contours have different subcategory.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
mari.shimode
Hi @sascari, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Mari Shimode
