Can you split a section at an angle
I was wondering if it was possible to split a section at different angles. I know that you can split the segment but how do I rotate only one of those segments?
loboarch
You can't rotate the split at an angle. You would need to create multiple sections at the different angles and then piece them back together.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
dferreira-blackwell
mitchell_smithJMZYU
I am working on a project that has an angled segment. I don't know how it was made. I would love to know.
RDAOU
@mitchell_smithJMZYU
That seems to be inline with the workarounds mentioned in the previous replies…are we looking at an element on a sheet, or an active view? Would you mind sharing how that looks in a model view which it intersects with?
Otherwise we may also continue discussion here >>> Revit Architecture Forum: rotate split elevation segment
