Can you have multiple tabs on second monitor?
djn9SY84
djn9SY84
Hey Guys,
On the primary revit screen there is a tab showing all the windows you have open. Shown below. TABS.png
But when i have a window in my secondary monitor i can only have on tab at a time, screenshot below. i want to be able to have multiple tabs i can toggle through like the above screen shot.
I know that you can have multiple windows on the secondary monitor.
I am wondering if there is an option to be able to have multiple tabs to toggle through?
Ryan_GormanKT36T
I don't believe it's possible to have tabs in the floating window.
But if you use the tile views option [ Views>Windows>Tiles Views ] you can have multiple Tabs in each tile.
djn9SY84
Thanks for your response.
it doesn't appear to be possible.
Alfredo_Medina
This solution should be un-marked, because it is possible to put multiple tabs on another monitor.
djn9SY84
What do you mean?
Alfredo_Medina
Sorry, reading your original question, now I see that you say that you can put multiple windows on a second monitor, but not arranged as tabs. Then, I take my previous comment back.
djn9SY84
i actually can make this solution work by stretching the window over two monitors. the only things is the ribbon is split at the top. That doesn't matter though. i only need to use it when im making steel connections.
