Can we change the size of temporary dimensions?
Hello
Can we change the size of the temporary dimensions?  How?
I want to make them bigger so I can read them.
Nardo
Accepted solutions (3)
loboarch
No.  The size of temporary dimensions is controlled at the system level and there is no user control afforded.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
cbcarch
Travel at your own risk:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
loboarch
New one to me. I did not know there was an INI switch for this.
FYI. Looks like 20pts is the maximum for the setting.
Jeff Hanson
Revit Help |
I did have to do a search for the file.  It is hidden in Revit 2018.  But is shows up when I searched for it.
FAIR59
no need to go hunting for the ini-file !!
Find the Options under the big Revit R,  on the [Graphics] page you can change the size of the temporary dimension.
