Can we calculate mass of a material in revit family instead of weight?
arghavan.A
arghavan.A
I wanted to ask if there is a way to calculate mass of a specific material in revit family instead of weight or volume?
(Assuming that we do not know the density)
Can't you get there through Materials and Physical Properties?
Mass = Density x Volume.
Why would you not know the material's density?  It is the easiest property to have and to have it correct.
FWIW: if you're using a new product, check the Manufacturer's website for that kind of information (i.e. density, etc.).
...many Manufacturers even offer Revit Content including Materials.
RDAOU
@arghavan.A
If you have the weight ... the Mass is equals Weight divided by the Acceleration of Gravity (M = W ÷ g)
arghavan.A
Thank you all. Just wanted to know if it is possible to get mass without manual conversion and calculation. In conclusion, the answer to the initial question is no - not directly.
arghavan.A
I had the environmental data of the product, but not the density.
