Hi everyone, can someone perhaps help. I need two cavity walls of different thicknesses to join correctly - see attached image. I need the wall to look the way the wall labelled 'correct display' looks in terms of the joining. Any help how to solve the wall layers and functions to achieve this?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Disallow join, extend the thinner wall overlapping the thicker one a distance of the finish layer, join geometry.
Create a Wall Type for these "corner wrap" conditions. The Wall Type, in this case, would be Brick only.
