Can this be done with Revit? (wall from 3D polyline)
Wojty1
Message 1 of 13
Wojty1
I wonder if Revit is capable of modelling a wall from a 3D polyline either by drawing on imported CAD (*.dwg) or with the help of planes, model lines and reference lines etc.
Here is a simple sketch of what I'd like to model:
Highly appreciate any hint or info if this could be done in Revit.
Maybe some Revit guru could also tell me how.
Best regards
Windows 10 Pro 64-bit | Civil 3D 2024+2025 / Revit 2024 (64-bit EN)
Intel Core i7-7700K / 2x 27" / 64 GB RAM / GeForce RTX 3060 OC V2
Windows 11 Pro 64-bit | All Autodesk Products 2023 - 2025
Intel Core i7-13850HX / 3x 27" / 128 GB RAM / nVidia RTX Ada 3500
Replies (12)
Message 2 of 13
Yes.
- Create an in place mass
- Draw the spline on plan, select it and create form
- Draw a shape on elevation around the form, select it and create a void form, stretch it to cut the surface form
- Finish the mass
- Create a Wall by face and select the surface
Message 3 of 13
azad.Nanva
You can also use Edit Profile for elevation:
Message 4 of 13
You are showing a flat wall.  I don't believe a curved wall can be profile edited, unless Autodesk added that functionality recently.
Message 5 of 13
RLY_15
Is that 3D polylines on both top AND bottom? Yikes.
Technically with Dynamo?
This is ultimately still the Wall.ByFace method, so cutting openings/modifying the wall after creation is going to be an absolute pain.
Message 6 of 13
azad.Nanva
Yes,this was for flat wall.
and for curve wall you can always use the Void element :
Message 7 of 13
Wojty1
@azad.Nanva many thanks for your effort. I only have Revit 2023 and 2024 available. Could you save it as 2024 Revit Project file?
Message 8 of 13
azad.Nanva
this is 2023:
Message 9 of 13
Wojty1
@azad.Nanva thanks a lot!
I'll try to follow your steps to recreate the wall.
This "problem" seem to be almost solved. I just need to practice.
Once the wall thing is done there comes another question
It's a real world example, a railway underpass:
Simplified it would look somehow like below picture
It took me the whole day to try to model it with no result.
So my final question would be how to achieve that.
many thanks in advance
Best regards
Message 10 of 13
azad.Nanva
I try this :
Message 11 of 13
Wojty1
Thanks @azad.Nanva
While I am still trying to understand what you did there I tried to model this wall using Swept Blends.
I wonder if your method is exactly the same as mine?
Can you confirm the exact result?
Which way is "better"?
Best regards
Message 12 of 13
Wojty1
While playing around with the modelling tools I'm stuck at an error:
Could someone explain why I cant apply a Void Swept Blend on a Swept Blend?
Message 13 of 13
azad.Nanva
Before close the edit mode ,use the void to cut a model or something ,if you don't use the void , Revit Delete it.In this situation , I prefer use the Mass.
