Aotomatic roof constraction in revitLT
3 ANTWORTEN 3
Nachricht 1 von 4
HEREVITCAD
153 Aufrufe, 3 Antworten
RevitLT is really behind other BIM software like SketchUp when it comes to roof construction.
it should be basic to get an option to add the wood rafters inside and outside.
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: HEREVITCAD
i usually do it using sloped glazing:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
HEREVITCAD
1. I would be happy to learn if you could explain how and what you do.
2. don't you think Revit would provide a better way to deal with this issue?
thanks
HIla
Nachricht 4 von 4
_Vijay
Hi @HEREVITCAD , use the Beam system it will help to host the roof.
