Can't work on Revit after updating Windows to 1903
Message 1 of 10
After updating windows to the latest version (1903) REVIT work very slow, to a point that I can’t work and had to move back to an earlier version of windows.
does anyone experience the same problem?
specs:
i7-8700
16gb ram
ssd
gtx1070
revit 2019
Replies (9)
Message 2 of 10
RobDraw
Without additional information, like OS/software versions, hardware specs, etc., it would be very difficult to speculate if anyone has the same problem?
Rob
Message 3 of 10
added
Message 4 of 10
kap-bimsupport
We're having this issue too.  I'm opening a support ticket with Autodesk.
Message 5 of 10
kap-bimsupport
Seems like the issue may be rooted with an anti-virus update as well.
Message 6 of 10
second time we try this update (windows 1903) on this machine and we tried it with other machine as well. autocad and revit work terribly slow with this update. please fix this. we cant update all of our machine because of this.
Message 7 of 10
kap-bimsupport
Did you check if disabling your antivirus helps to resolve the issue?  This would be done as a test only, but if it does help you could work from that point.
Message 8 of 10
Did you get any updates on this.? Any Solutions.?
Message 9 of 10
unfortunately the only option is to stop updating windows.
Message 10 of 10
And even more: i using now a much stronger machine and the same problem here also.
i7-9700
32 gb ram
NVMe
Quadro P4000.
