Can't window select topo points
Base12
Message 1 of 9
Base12
When in edit toposurface mode i can single-click select each point, but if I window select around a bunch of them, none of them are selected.  I'm trying to flatten out a large area by setting all the points to the same elevation but there's 100 or so of them.  It was literally faster to post this here and wait for a response than to pick them all individually.
Replies (8)
Message 2 of 9
GHASEM_ARIYANI
hi
1-select topsoil.
2-expand shape editing panel.
3- Be sure to active Preview Points.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 9
Base12
Displaying the points is not the problem.
Message 4 of 9
GHASEM_ARIYANI
if you need to change multiple points> from ribbon> Modify sub-elements panel.
If you don't mean this either. Unfortunately, I did not understand your problem.
If you can show the problem better by attaching a video or photo, maybe we can provide a more accurate answer.
Message 5 of 9
handjonathan
Hi @Base12
Thanks a lot for posting your question to the forums!   Has the solution suggested by @GHASEM_ARIYANI helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 6 of 9
Base12
The issue has not been resolved.  This does not seem like a settings problem since the points are visible, and they can be selected individually - I don't know how I can explain it more clearly.  When you select a window around the points they are just ignored/not selected.
Message 7 of 9
GHASEM_ARIYANI
Hello
Can you show the steps with a short video?
Message 8 of 9
SteveKStafford
Does your firm use Guardian? A friend's firm discovered a conflict with it that produces an issue. In their situation it disables the delete key when points are selected. Maybe this is related?
Steve Stafford
Message 9 of 9
Base12
We don't use Guardian but there are a couple other plugins we do use.  I'll disable those and if it solves it I'll report back.  Thank for the tip.
