Can't undo after changing any views title?!
gnarkill283
Message 1 of 10
gnarkill283
Is my Revit messed up? I don't always notice it because I don't always need to undo what I'm doing but when I change something as simple as a drafting view's title, my undo option becomes greyed out. This is pretty messed up as I could lose tons of work if I delete something by mistake and can't undo it. Is this the regular Revit behavior?
Replies (9)
Message 2 of 10
What happens if you use the keyboard shortcut for Undo?
Message 3 of 10
gnarkill283
ctrl z is the first thing I try. This also doesn't always happen when editing drafting views. I just tried it out on editing the title of a sheet and it does it every time. Can't undo if I change a sheet title...
Message 4 of 10
what version of Revit?
Message 5 of 10
gnarkill283
Message 6 of 10
I renamed View Title of the view placed on Sheet and View name via Browser and the Undo list was not affected.
Message 7 of 10
Interesting. It would be be helpful to know the exact sequence of commands that led up to the Undo counter "zeroing-out". I'd like to try and replicate.
Message 8 of 10
I have the same problem on 2017.2. Renaming things in the Project Browser makes Undo unavailable.
Message 9 of 10
cathy.choiQCNVL
Run a wall opening in dynamo editor, which change the whole model wrong way and can not undo either.
Message 10 of 10
quentin.andreotti
Same problem with Revit 2022.... I constantly loose all my undo after renaming a view.(not even the one I'm working in). It is not possible to work like this.
