Can't tag area in an area plan
hliS658H
hliS658H
I  created an area plan (Gross Building) for a mezzanine level, unchecked "apply area rules", I manually drew the area boundaries, obviously, two walls are interior walls instead of exterior walls. I tried to tag the area, nothing happened. Not sure about the reason, but suspect if this is because of used exterior walls? How to fix it?
You need to place areas in order to tag them.
