I have a Door Schedule and a Door Key, but the pull down is not available in the Schedule.
I have a similar setup with Room Schedule and Room Key, and the pull down works fine.
Am I missing something simple? Thanks!
Did you create a Named Door Key Schedule (w/Fields) and then put the Named Key Schedule Parameter and Fields into the Door Schedule?
...Doesn't look like any Data Rows are defined in the Door Key Schedule
Door key was created, and the parameter name added to the door schedule.
The strange part is that it has worked previously...
When i go to recreate a new key, say "door key #2", the list of fields does not include those in the current key
I had the same issue. You need to uncheck "Include Elements in Links" in the Fields window. See image if you don't know where it is.
