Can't see Shower Wall Tile in Elevation
sbernsto
sbernsto
Hi All,
I am learning Revit and using both Udemy training courses and Youtube to gain knowledge.  I'm working on a shower renovation and having trouble with viewing Tile in Elevation.
I created the tile wall using TheRevitKid method in this video: https://www.youtube.com/watch?v=zber4XiPu_o
Specifically, I created a new wall type that is 1/2 inch thick and the material is a new material.  I created a surface pattern (specifically a model pattern).  In 3D view, the tile looks great, but when I switch to an elevation view, I only see the smooth wall and no tile.  Any suggestions?
Simon_Weel
vitorbortoncello
check the override:
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
