Can't see level 1 underlay on level 2?
Hi all,
I am unable to view the outline of what I just drew  on  level 1 on my level 2 floor plan. I changed the underlay properties on the properties palette to Level 1. Along with changing the top constraint for each wall as well. I am fairly new to Revit, so any help is greatly appreciated!
Taylor.
KraiggC
In your view range; What is your bottom and view depth set at? Start with unlimited and see if that helps. If it doesn't it may be a visibility graphics issue, although I doubt it.
Is the Underlay looking up or down?
Looking down.
Can you zip and share your file?
Corsten.Au
Check
1. Phase
2. Phase of ELement
3. change the View range ( Base level and Top Level )
Best luck
Corsten
Building Designer
jameshNTDKG
Community Visitor
Community Visitor
YES! This was the answer I came here for. Tip of the hat!
