Can't rotate a family that I created
talha_ozdemir
Message 1 of 12
talha_ozdemir
Hello, I created a family recently and then I loaded it into another project. I am unable to rotate it in the project.
Any solutions ?
Replies (11)
Message 2 of 12
indiana_j0nes
Hi @talha_ozdemir ,
Welcome to the Forums, I see you're using Revit 2022 and you're facing this issue on a custom Familie you developed.
Could you kindly elaborate on this, so that other users can point to in the right direction/ or explain probable causes?
1. What kind of Family is this? maybe the template has certain restrictions.
2. Is it possible to post the family here so others can take a look at it?
3. From the looks of it, I assume it's a metal profile? What is your requirement like? Does it need to look like this in Detail as well as 3D or can it be simplified to just a rectangular profile in geometry? (May save you relative family file size).
A little more description would be very helpful to narrowing it down or finding a better workaround.
Cheers, K
Kunal Tuljaram Gaidhankar
Message 3 of 12
talha_ozdemir
Hello again, the family template is generic model. And I am also
uploading the family, it is very simple family profile for the window panels.
I created this family and uploaded to the host family, I am also uploading an image
so you can take a closer look.I constrained family to the bottom of the panel, and I also
need to constrain a copy of it to the top part, but before doing that I need to rotate the family. It
should be just a simple task, but it wont let me rotate.
Message 4 of 12
If this family was supposed to be used in different orientations, you should have planned for that, either making the family face-based or making two versions of the family, one for each orientation. The face-based would have been the easiest solution. The second solution is not difficult either.
Another solution, more involved, is to make this family work-plan based and use another intermediate family (after this one and before the host) to create a rotation parameter.
Message 5 of 12
syman2000
Family by default cannot rotate in z direction. So you have to set it to work-plane base
In the project you create a reference plane and give it a name
Host the family on the reference plane and you can rotate it by rotating reference plane.
Message 6 of 12
Are you saying that you want to rotate this family in a Host Family, as if it were hinged on one side?
....if so, make the nested Family a Work Plane-Based Family and then place it on a Ref. Line Work Plane in the Host.  Control the Rotation Angle of the Ref. Line via a labeled dimension in the Host.
Message 7 of 12
I take that you need to use the same component for base and head of a panel.  If so, tick Workplane box in the family as you have been advised then you can host it on the base and top reference planes, without having to rotate anything.
https://knowledge.autodesk.com/community/screencast/5a792ec8-f411-4fc3-9f81-06684dac8b57
Message 8 of 12
sagnewYUXLR
its still one of the most frustrating aspects of revit, just want to be able to simply rotate a family but no
Message 9 of 12
serkan_dizdarMUNW4
Community Visitor
Community Visitor
Revit 2018 de aileyi "Mechanical Equipment" olarak kaydettiğimde her eksende döndürebiliyordum. Revit 2025 kullanıyorum ve bu değişmiş, artık dönmüyor. Bu neden değişti acaba?
Message 10 of 12
sagnewYUXLR
i think when creating the family you have to have "always vertical" ticked
simple filter i created
can be rotated
Message 11 of 12
RSomppi
All of the families that I make and use can be rotated all day long. Been doing it since day one. If you start a thread and ask for help, someone will help you.
Message 12 of 12
sagnewYUXLR
yeah i',m all good now thanks was more in response to the person who was struggling since switching versions
