Can't Remove a Void
PhilvK
Can't Remove a Void
PhilvK
I created a void extrusion and used it in a wall to get an angled end at the wall. I now want to remove the void but can't find it, or a way to remove it. Using Uncut doesn't seem to work either as the void form is either gone or terminally invisible!
Tabbing on that angle of the wall created by that void won't work?
PhilvK
Correct, I can't find the void by tabbing.
RDAOU
@PhilvK
Cut and paste back same place should remove an in-place void (See Gif 1)
Alternatively you could use phase filter to reveal demo (See Gif 2)...this makes it easier to
  • either select the void
  • or SELECT the demo portion and delete it...This will automatically delete the Void cut
PhilvK
I copy clipped into a new project and can now see it. I'll just redo the wall.
RDAOU
@PhilvK
You tried the above and didn't work too!!!
PhilvK
Cut and paste it back in place worked. Thank you!
