Can't open revit 2023
- Mute
- Permalink
- Report
Hello. Revit 2023 isnt working for me, it instantly crashes even after a clean install..
I dont know why, bellow is the error codes:
' 0:< Initial VM: Avail 134213370 MB, Used 18 MB, Peak 18; RAM: Avail 24053 MB, Used 38 MB, Peak 18
' 0:< GUI Resource Usage GDI: Avail 10000, Used 0, User: Used 1
'C 04-May-2023 15:28:09.364; ->UI-less InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Metric Library=C:\REVIT\Libraries\English\ (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -12 -> 134213359 MB, Used +2 -> 21 MB, Peak +2 -> 21 MB; RAM: Avail -34 -> 24019 MB, Used +5 -> 43 MB, Peak +5 -> 43 MB
' 0.619345 1:<<<wait for ForgeUnitsAdapter::configureFolders
' 0:< ::0:: Delta VM: Avail -10 -> 134213349 MB, Used +0 -> 22 MB, Peak +0 -> 22 MB; RAM: Avail -74 -> 23946 MB, Used +2 -> 46 MB, Peak +2 -> 46 MB
' 0:< GUI Resource Usage GDI: Avail 10000, Used 0, User: Used 2
'C 04-May-2023 15:28:10.366; ->loadAllDB (this=000002B6C7E5D0B0)
' 0:< ::0:: Delta VM: Avail -176 -> 134213173 MB, Used +15 -> 37 MB, Peak +15 -> 37 MB; RAM: Avail -31 -> 23915 MB, Used +58 -> 105 MB, Peak +58 -> 105 MB
'C 04-May-2023 15:28:10.539; <-loadAllDB (this=000002B6C7E5D0B0)
' 0:< ::0:: Delta VM: Avail -2 -> 134213172 MB, Used +2 -> 40 MB, Peak +2 -> 40 MB; RAM: Avail -68 -> 23848 MB, Used +5 -> 110 MB, Peak +5 -> 110 MB
' 0:< SystemSettings:
' 0:< 12=multiCoreCharacteristic
' 0:< true=isDotNetInstalled
' 0:< 4.8.09032(533320)=dotNetInstalledVersionString
' 0:< false=isProcessUserModeExceptionPolicyDisabledForCallbackFilter
' 0:< ::0:: Delta VM: Avail -123 -> 134213049 MB, Used +14 -> 54 MB, Peak +14 -> 54 MB; RAM: Avail -77 -> 23771 MB, Used +24 -> 135 MB, Peak +24 -> 135 MB
' 0:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 9
' 0:< Autodesk Revit 2023
' 0:< 64-bit load point = C:\REVIT\Revit 2023
' 0:< this journal = C:\Users\jona5\AppData\Local\Autodesk\Revit\Autodesk Revit 2023\Journals\journal.0005.worker1.log
'C 04-May-2023 15:28:11.313; Journal Init
'C 04-May-2023 15:28:11.313; 0:< Log Summary
' 0:< .Marshalling
' 0:< ...CompactCaching = 1 (Enabled)
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 51
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 12
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
'C 04-May-2023 15:28:11.313; BC: 0,0,0
' 0:< API_SUCCESS { Registered an external service: Name(DirectContext3D Service); VendorId(ADSK); ServiceId(e454a471-b9f3-4cb7-96b1-bab4cf7742a6) }
' 0:< API_SUCCESS { Registered an external service: Name(External Data Type Service); VendorId(ADSK); ServiceId(e05a890c-311f-47e5-9652-ebfb7da7663c) }
' 0:< API_SUCCESS { Registered an external service: Name(External Resource Service); VendorId(ADSK); ServiceId(b3892e5f-9161-4bbc-958a-c8ef75e94e96) }
' 0:< API_SUCCESS { Registered an external service: Name(External Data Type Service); VendorId(ADSK); ServiceId(8b40f7b3-625b-4e63-8f95-0252f3c488ff) }
' 0:< API_SUCCESS { Registered an external service: Name(Generic Repository Helper Service); VendorId(ADSK); ServiceId(cf24951a-62aa-4c7c-a26a-cdb1379b3649) }
' 0:< API_SUCCESS { Registered an external service: Name(AXM Importer Service); VendorId(ADSK); ServiceId(af2183c2-e854-41cf-85bb-fe0675f12181) }
' 0:< API_SUCCESS { Registered an external service: Name(NavisworksExportService); VendorId(ADSK); ServiceId(a9bdf0fd-2632-429e-bc35-50ebc2b824d2) }
' 0:< API_SUCCESS { Registered an external service: Name(External Parameter Service); VendorId(ADSK); ServiceId(0d4ef84e-987b-4106-9a53-2b460ec38abc) }
' 0:< API_SUCCESS { Registered an external service: Name(EntitlementExternalService); VendorId(ADSK); ServiceId(9111ab07-9bd9-4b68-a01f-c0a0dcae1564) }
' 0:< API_SUCCESS { Registered an external service: Name(ModelAccessValidationService); VendorId(ADSK); ServiceId(584ac31c-5e21-4892-95b5-382680d021bf) }
' 0:< API_SUCCESS { Registered an external service: Name(CloudExternalService); VendorId(ADSK); ServiceId(279080e0-8c45-44eb-9027-d4eb37ece90d) }
' 0:< API_SUCCESS { Registered an external service: Name(Infrastructure Alignment Information Service.); VendorId(ADSK); ServiceId(7ca4bc09-66de-4fed-93db-5c8e02874e9d) }
' 0:< API_SUCCESS { Registered an external service: Name(ExternalDataManagerService); VendorId(ADSK); ServiceId(f036684f-7c8a-4f51-88aa-12dee1414d7b) }
' 0:< API_SUCCESS { Registered an external server: Name(TestServer); VendorId(ADSK); ServerId(b9ac22ad-3594-4bf8-94a1-d14651d5b4be); ServiceId(f036684f-7c8a-4f51-88aa-12dee1414d7b) }
' 0:< API_SUCCESS { Registered an external service: Name(Code Checking Parameter Service); VendorId(ADSK); ServiceId(de6db8de-dea6-40bd-9503-4ffe62ff6143) }
' 0:< API_SUCCESS { Registered an external service: Name(Hole Definition Service); VendorId(ADSK); ServiceId(9d39d4fe-6e5f-4088-8655-b349d00e864a) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Ranges of applicability Service); VendorId(ADSK); ServiceId(f04d2d31-5d7d-4ec0-8a2b-c52fbd6d83c5) }
' 0:< API_SUCCESS { Registered an external service: Name(FramingProfileService); VendorId(ADSK); ServiceId(b2f816c0-6493-4537-8067-78a4e67f559e) }
' 0:< API_SUCCESS { Registered an external service: Name(Modify Connection Parameters Service); VendorId(ADSK); ServiceId(e9c0f948-320e-4e7f-a573-10755555305d) }
' 0:< API_SUCCESS { Registered an external service: Name(Connection Type Changed Service); VendorId(ADSK); ServiceId(e31c3100-9cab-4303-b85b-4171703ce1c4) }
' 0:< API_SUCCESS { Registered an external service: Name(Section Type Parameter Service); VendorId(ADSK); ServiceId(c42c9b55-c491-4611-97e9-9e617958e13e) }
' 0:< API_SUCCESS { Registered an external service: Name(Site Insert Service); VendorId(ADSK); ServiceId(c9979a42-11ab-4c25-93e1-abfb50b7be60) }
' 0:< API_SUCCESS { Registered an external service: Name(RebarUpdateService); VendorId(ADSK); ServiceId(a2c22b44-c231-4d3f-b653-b81b6f8be150) }
' 0:< API_SUCCESS { Registered an external service: Name(Path of travel calculator); VendorId(ADSK); ServiceId(ee502325-58ce-4d6e-9a2c-643608b1fbd9) }
' 0:< API_SUCCESS { Registered an external service: Name(Internal Forces Service); VendorId(ADSK); ServiceId(a97444aa-af8d-4a1e-af1f-fa7b77b368ee) }
' 0:< API_SUCCESS { Registered an external service: Name(ATF Service); VendorId(ADSK); ServiceId(bb3a96c9-e04a-40e4-8ecf-1464dd6aa7eb) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Fitting/Accessory Pressure Drop Calculator); VendorId(ADSK); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external service: Name(Duct Pressure Drop Calculator); VendorId(ADSK); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external service: Name(Pipe Pressure Drop Calculator); VendorId(ADSK); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external service: Name(Plumbing Flow Calculator); VendorId(ADSK); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Export Service); VendorId(ADSK); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Exporter); VendorId(ADSK); ServerId(ef8d0493-7f36-42b5-b9aa-8aaac716482b); ServiceId(d8b95737-f943-414c-9ad7-86785bf1acbc) }
' 0:< API_SUCCESS { Registered an external service: Name(IFC Import Service); VendorId(ADSK); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
' 0:< API_SUCCESS { Registered an external server: Name(Revit IFC Importer); VendorId(ADSK); ServerId(660a7370-f6d6-43c8-8456-6b2eea785110); ServiceId(98d317e2-e943-4cc0-a3da-2edf32a5d942) }
'C 04-May-2023 15:28:11.318; 0:< manage debug modes
'C 04-May-2023 15:28:11.318; 0:< MFCApp::testGraphicsHardware
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< START updateCanUseHardware
' 1:< ::0:: Delta VM: Avail +44 -> 134213094 MB, Used +2 -> 57 MB, Peak +14 -> 69 MB; RAM: Avail -174 -> 23598 MB, Used +3 -> 138 MB, Peak +7 -> 142 MB
' 1:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 9
' 1:<
'OGS Device Memory Size: 20199 MB
' 1:< ::0:: Delta VM: Avail -342 -> 134212753 MB, Used +161 -> 219 MB, Peak +151 -> 220 MB; RAM: Avail -35 -> 23563 MB, Used +32 -> 170 MB, Peak +29 -> 171 MB
' 1:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 11
' 1:< DX Device: DirectX 11, Hardware
' 1:< DX Device: DirectX 11, WARP
'C 04-May-2023 15:28:15.944; 1:< START video card certification
' 1:<
'Current driver version: 31.0.15.2879
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GTX 1650" ManufacturerID="10DE" DeviceID="1F91" osID="8000" DRIVER="31.0.15.2879" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 04-May-2023 15:28:15.998; 1:< FINISH video card certification
' 4.680186 1:<<<updateCanUseHardware
' 0:<
'Can use hardware=y
'Hardware support flags:
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'SoftwareModeForced=n
' 0:< FINISH CanUseHardware(forced)
'C 04-May-2023 15:28:15.998; 0:< MFCApp::testMSAA
'C 04-May-2023 15:28:15.998; <-UI-less InitNativeInstance
'C 04-May-2023 15:28:15.998; ->UI-less InitManagedInstance
' 0:< ::0:: Delta VM: Avail -591 -> 134212162 MB, Used +48 -> 267 MB, Peak +46 -> 267 MB; RAM: Avail +55 -> 23619 MB, Used +52 -> 223 MB, Peak +51 -> 223 MB
' 0:< GUI Resource Usage GDI: Avail 9989, Used 11, User: Used 12
' 0:< To make IFC server work.
' 0:< ::0:: Delta VM: Avail -179 -> 134211984 MB, Used +50 -> 317 MB, Peak +51 -> 318 MB; RAM: Avail -375 -> 23245 MB, Used +77 -> 301 MB, Peak +78 -> 302 MB
' 0:< API_SUCCESS { Registering ApplicationInitialized event by application ATF Translation Server (fa3d130b-2b6b-45be-8734-67536086143f). }
' 0:< API_SUCCESS { Starting External DB Application: ATF Translation Server, Class: ATFTranslationServer.ATFTranslationServerRegister, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\REVIT\Revit 2023\AddIns\ATFTranslationServer\Autodesk.ATFTranslationServer.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< Third Party Updater 'AlignmentsDB: Update or delete alignment station labels.' registered for all documents.
' 0:< Third Party Updater 'AlignmentsDB: Update alignment depending on units.' registered for all documents.
' 0:< ::0:: Delta VM: Avail 134211984 MB, Used 317 MB; RAM: Avail -15 -> 23230 MB, Used +3 -> 304 MB, Peak +3 -> 305 MB
' 0:< API_SUCCESS { Registered an external server: Name(AecAlignment Server); VendorId(ADSK); ServerId(0558397d-5761-4a0d-8883-42a166446d81); ServiceId(7ca4bc09-66de-4fed-93db-5c8e02874e9d) }
' 0:< API_SUCCESS { Starting External DB Application: AlignmentsDB, Class: Autodesk.Revit.DB.Infrastructure.AlignmentsDBApplication, Vendor : ADSK(Autodesk, www.autodesk.com), Assembly: C:\REVIT\Revit 2023\AddIns\CivilAlignments\Autodesk.CivilAlignments.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.CoordinationModelDB.CoordinationModelDBApplication (C:\REVIT\Revit 2023\AddIns\CoordinationModel\Autodesk.CoordinationModelDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication EntitlementDB.EntitlementDBApplication (C:\REVIT\Revit 2023\AddIns\ModelBrowser\Autodesk.Entitlement.Utilities.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication Autodesk.LightboxDB.Main (C:\REVIT\Revit 2023\AddIns\Lightbox\Autodesk.LightboxDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication SiteLinker.SiteServerApp (C:\REVIT\Revit 2023\AddIns\SiteLinker\Autodesk.LinkTopography.Parser.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication Autodesk.Revit.DB.ResultsBuilder.ResultsBuilderApplication (C:\REVIT\Revit 2023\AddIns\ResultsManagerExplorer\Autodesk.ResultsBuilder.DBApplication.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registering DocumentClosing event by application Route Analysis (40e082fd-2661-4bbb-83f0-e960745a72a2). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Route Analysis (40e082fd-2661-4bbb-83f0-e960745a72a2). }
' 0:< API_SUCCESS { Registered an external server: Name(Simulex (tm) Calculation); VendorId(ADSK); ServerId(3ac50ffe-852f-4a77-941f-851ddfbcbd57); ServiceId(ee502325-58ce-4d6e-9a2c-643608b1fbd9) }
' 0:< API_SUCCESS { Starting External DB Application: Route Analysis, Class: RouteAnalysisDB.RouteAnalysisDBApplication, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Path%20of%20Travel&sort=score&page=1&kn...), Assembly: C:\REVIT\Revit 2023\AddIns\RouteAnalysis\Autodesk.RouteAnalysis.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ::0:: Delta VM: Avail -3 -> 134211981 MB, Used +1 -> 319 MB, Peak +2 -> 321 MB; RAM: Avail -22 -> 23209 MB, Used +5 -> 310 MB, Peak +6 -> 312 MB
' 0:< API_SUCCESS { Registering DocumentCreating event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentCreated event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentClosing event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSaving event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSavingAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSaved event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSavedAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentChanged event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentClosed event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering LinkedResourceOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering LinkedResourceOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSynchronizingWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Registering DocumentSynchronizedWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< Third Party Updater 'Steel Connections DB extension: Steel Fabrication Updater' registered for all documents.
' 0:< ::0:: Delta VM: Avail -75 -> 134211907 MB, Used +9 -> 329 MB, Peak +8 -> 329 MB; RAM: Avail -69 -> 23141 MB, Used +19 -> 330 MB, Peak +18 -> 330 MB
'C 04-May-2023 15:28:33.963; 0:< Checking SQL instance SteelConnections2023 health...
' 0:< ::0:: Delta VM: Avail 134211907 MB, Used 329 MB; RAM: Avail -285 -> 22856 MB, Used 330 MB
'C 04-May-2023 15:28:35.093; 0:< Testing connection to Steel Connections databases...
' 0:< ::0:: Delta VM: Avail -237 -> 134211670 MB, Used +61 -> 391 MB, Peak +62 -> 391 MB; RAM: Avail -112 -> 22744 MB, Used +109 -> 440 MB, Peak +109 -> 440 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
' 0:< API_SUCCESS { Starting External DB Application: Steel Connections DB extension, Class: Autodesk.SteelConnectionsDB.Main, Vendor : ADSK(https://knowledge.autodesk.com/search?search=detailed%20steel%20modeling&p=REVITPRODUCTS&sort=score), Assembly: C:\REVIT\Revit 2023\AddIns\SteelConnections\Autodesk.SteelConnectionsDB.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.Revit.DB.StructuralRibbon.Application (C:\REVIT\Revit 2023\AddIns\ResultsManagerExplorer\Autodesk.StructuralRibbon.Application.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication ConnectedDesktopDB.ServerApp (C:\REVIT\Revit 2023\AddIns\ConnectedDesktop\ConnectedDesktopDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication KeynoteDBServer.ServerApp (C:\REVIT\Revit 2023\AddIns\Keynote\KeynoteDBServer.dll) was not loaded in RevitWorker
' 0:< API_SUCCESS { Registered an external server: Name(Plumbing Fixture Flow); VendorId(ADSK); ServerId(56121d7d-e1d7-42a3-bed8-f4d1d32058c8); ServiceId(bf0da776-5307-4747-8285-f358e92a90d0) }
' 0:< API_SUCCESS { Registered an external server: Name(Altshul-Tsal Equation); VendorId(ADSK); ServerId(042a10e0-8d24-46a4-9596-d192b3125d0c); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(2e9a77c0-62a0-4693-9442-33312be60ad7); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Haaland Equation); VendorId(USERADDIN); ServerId(58ea1b7c-2fca-453f-9ab9-7a3b9927ecc1); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(e395a0ec-48a4-4255-b957-afbb3d73cb67); ServiceId(8c707bd6-ecd6-4150-a0df-bd6c85dd9bb0) }
' 0:< API_SUCCESS { Registered an external server: Name(Colebrook Equation); VendorId(USERADDIN); ServerId(0875f550-6141-4e34-a6b7-547cf9cfda01); ServiceId(62d13e0c-9fe1-4d8e-a0c7-1f93d24cf3f3) }
' 0:< API_SUCCESS { Starting External DB Application: Straight Segment Pressure Drop Servers, Class: StraightSegmentCalculationServers.ServerApp, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Pipe%20Pressure%20Drop&sort=score&page=...), Assembly: C:\REVIT\Revit 2023\AddIns\MEPCalculation\Autodesk.MEP.SegmentCalculation.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(76eff5da-2e71-45f7-b940-cc5716328ba0); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Coefficient from ASHRAE Table); VendorId(ADSK); ServerId(8baf7d75-8b9b-46d0-b8ce-3ad1c19e6b19); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(5a598293-1504-46cc-a9c0-de55c82848b9); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(46245996-eebb-4536-ac17-9c1cd917d8cf); ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540) }
' 0:< API_SUCCESS { Registered an external server: Name(Not Defined); VendorId(ADSK); ServerId(61e7b8e1-16d1-4fe4-82f0-327af736323f); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(K Coefficient from Table); VendorId(ADSK); ServerId(51dd5e98-a9dd-464b-b286-4a37953610bf); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Coefficient); VendorId(ADSK); ServerId(32d58662-b467-4f7b-b728-f6ad7b7ba5e3); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Registered an external server: Name(Specific Loss); VendorId(ADSK); ServerId(16f4f7be-0ac0-461d-a9a4-1d3511cd280e); ServiceId(b8656566-e4ef-4e6a-bedb-9ecc6b5a2780) }
' 0:< API_SUCCESS { Starting External DB Application: Fitting And Accessory Pressure Drop Servers, Class: FittingAndAccessoryCalculationServers.ServerApp, Vendor : ADSK(https://knowledge.autodesk.com/search?p=REVITPRODUCTS&search=Fitting%20Pressure%20Loss&sort=score&pa...), Assembly: C:\REVIT\Revit 2023\AddIns\MEPCalculation\Autodesk.MEP.FittingCalculation.DBApplication.dll, Assembly Version: 23.1.10.4 }
' 0:< ExternalDBApplication Autodesk.Revit.UI.Collaborate.CollaborateDBApplication (C:\REVIT\Cloud Models for Revit 2023\CollaborateDB.dll) was not loaded in RevitWorker
' 0:< ExternalDBApplication AXMImporterWrapper.AXMImporterApp (C:\REVIT\FormIt Converter for Revit 2023\AXMImporter.dll) was not loaded in RevitWorker
' 1:< ::0:: Delta VM: Avail -2 -> 134211669 MB, Used 391 MB, Peak +2 -> 394 MB; RAM: Avail -58 -> 22687 MB, Used +1 -> 441 MB, Peak +3 -> 443 MB
' 1:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 13
' 1:< API_SUCCESS { Registered an external server: Name(ATFTranslationServer); VendorId(ADSK); ServerId(252f643e-9927-4c06-a704-4a8b3587b979); ServiceId(bb3a96c9-e04a-40e4-8ecf-1464dd6aa7eb) }
'C 04-May-2023 15:28:51.512; <-UI-less InitManagedInstance
'C 04-May-2023 15:28:51.512; 0:< RevitWorker.exe 1
'C 04-May-2023 15:28:51.513; ->UI-less ExitManagedInstance
' 0:< Third Party Updater 'Steel Connections DB extension: Steel Fabrication Updater' has been unregistered.
' 0:< API_SUCCESS { Unregistering DocumentCreating event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentCreated event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< ::0:: Delta VM: Avail 134211669 MB, Used +0 -> 392 MB; RAM: Avail +34 -> 22721 MB, Used +0 -> 442 MB
' 0:< API_SUCCESS { Unregistering DocumentOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentClosing event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSaving event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSavingAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSaved event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSavedAs event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentChanged event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering LinkedResourceOpened event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering LinkedResourceOpening event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizingWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< API_SUCCESS { Unregistering DocumentSynchronizedWithCentral event by application Steel Connections DB extension (9f2e732a-289e-4185-b701-15d33c31653f). }
' 0:< ::0:: Delta VM: Avail +17 -> 134211687 MB, Used -4 -> 388 MB; RAM: Avail +70 -> 22791 MB, Used -8 -> 434 MB
' 0:< Forcibly unregistering Updater with id:c94154ad-4bbe-4682-a816-73cc79e2a9d0
' 0:< Forcibly unregistering Updater with id:5a37bca6-58d6-44b0-bf9a-5da8ee33a464
' 0:< Forcibly removing all update triggers for all Updaters
' 0:< Unregistering all external services.
'C 04-May-2023 15:28:52.069; <-UI-less ExitManagedInstance
'C 04-May-2023 15:28:52.069; ->UI-less ExitNativeInstance
' 0:< ::0:: Delta VM: Avail +200 -> 134211887 MB, Used -145 -> 243 MB; RAM: Avail +10 -> 22801 MB, Used -10 -> 425 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 12
'C 04-May-2023 15:28:52.117; Journal Exit
'C 04-May-2023 15:28:52.117; BC: 0,0,0
' 0:< FormOrAbandon exec= 1 (parallel= 0) self= 0.000097 sec (avg= 0.000)
' 0:< InstrumentationTask exec= 1 (parallel= 1)
' 0:< TaskFileExists exec= 341 (parallel= 334)
' 0:< ::0:: Delta VM: Avail +48 -> 134211935 MB, Used -5 -> 238 MB; RAM: Avail +15 -> 22817 MB, Used -15 -> 411 MB
' 0:< GUI Resource Usage GDI: Avail 9988, Used 12, User: Used 11
'C 04-May-2023 15:28:52.199; <-UI-less ExitNativeInstance
