Can't make the accessor's map
amirhossein.jafarii
amirhossein.jafarii
Hi All,
Can someone help me with the drawing of the property line of the accessor's map?
I want to draw to draw the marked property in Revit using distance and bearing.
Lachlan-JWP
What are you having an issue with? The image look like it has all the information you need.
The quickie way would be to just insert that image into Revit, scale it using the Scale Tool, create Property Lines by Sketch Method, close out and convert Sketch to Table and then edit Table and modify the Segment Lengths.  If Bearings are really necessary, which I suspect aren't if you are doing a Plot Plan, then set up and orient to True North.
