Can't make arc in curved wall?
How to create arc opening in curved wall & how to create window in curved wall?
Ilic.Andrej
You can use any common window on a curved wall. Instead of using wall opening, use an in-place void to create arc opening on a curved wall.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
loboarch
Here is a screencast showing the technique dr. grozozo is describing.  I just happened to have an old one on hand.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
ennujozlagam
You can check this link. Thanks
https://youtu.be/iADhgdPjhr4
GHASEM_ARIYANI
hello @Anonymous
https://knowledge.autodesk.com/community/screencast/b1d211bf-f9ab-4628-ad26-d7f279ee689f
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
