Can't link specific IFC 2x3 in Revit 2022
gvanolst
gvanolst
I'm trying to link or open the attached IFC-file in Revit 2022.1.21.13 (Ifc Exporter 22.4) but it doesn't show anything. When I try to open it I get an error that it is unable to open it.  When I try it in Revit 2021 it works fine.
thamizhz
Unable to import/open an IFC file in Revit 2022.
The file appears to keep loading for more than thirty minutes but does not succeed or nothing is imported.
Causes:
  • IFC is too large and complex.
  • IFC is imported and exported from Revit. Revit IFC workflow was originally not designed for the situation "roundtrip" between different Revit versions, but primarily for the communication with other software.
  • IFC4 file.
  • IFC4x1 file.
Solution:
To resolve this issue, try one or more of the following:
  • Link the IFC into Revit rather than opening it.
  • Divide IFC model into smaller parts and link smaller IFCs instead, because *.IFC.RVT created by Linking must be smaller than 2GB.
  • If IFC is imported and exported from Revit, refer the information given below:
    • The IFC format is designed to export specific data and share the data with other software products. Exporting and importing data from and to the same software, or round-tripping, is neither supported or certified from the creator of the format IFC Building Smart.
  • In the case of IFC4 file, use Revit 2022 or newer.
  • In case of IFC file size 1+GB, use Revit 2022.1 or newer.
  • ​​​​​​​Use IFC2x3.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Can-t-op...
gvanolst
Found my solution over here:
https://github.com/Autodesk/revit-ifc/issues/434
