Can't get degree value if using number parameter
netsonicyxf
Message 1 of 9
netsonicyxf
E.g.
x is defined as number type parameter in family, and x = 0.02.
y and z is defined as degree type parameter in family.
If I type formula "=atan(x) in the y formula field, it can't calculate the y value.
But if I type formula "=atan(0.02)  in the z formula field, it can calculate y = 0.146°
Replies (8)
Message 2 of 9
netsonicyxf
Please ignore the 1st post,
E.g.
x is defined as number type parameter in family, and x = 1.
If I type formula "=atan(x) in the y formula field, it calculate the y value, but the y value is EDITABLE.
But if I type formula "=atan(1)  in the z formula field, the Z value is NOT editable.
Message 3 of 9
martijn_pater
x is not 0.02 and/or parameters are not defined as described... edit: ok, let's review second post. edit 2: atan(1) is not a variable.
Message 4 of 9
netsonicyxf
I know if something is inputed in the formula field, the result should be greyed out - not editable, like what Z shows.
But why Y result can still be editable even if it has a formula =atan(x)?
Message 5 of 9
martijn_pater
The formula adjusts either way.
Message 6 of 9
martijn_pater
...however if you add multiple variables it can not, atan(a+b) ie. a and b being seperate number parameters.
Message 7 of 9
Yeah, I don't like it either when a formula doesn't lock down (gray out) the parameter. I usually stick in an if statement into the formula.  for example =if(1=1, atan(x), atan(x))
Message 8 of 9
Message 9 of 9
The formula should adjust either way. The degree value is correct.
