Can't find Grid Line in Object Styles
Hi Everyone.
I think the title is self-explanatory. I am trying to reduce the visual impact of the Grids in the Floor Plan but can't find them neither in Object Styles nor in Visibility Graphics.
Plus, in the Type Properties of the Grid Revit is telling me that the segment is using Weight Line 1, which isn't true because Line 1 is way more thin than what I am seeing on the view
I am posting an image containing some mullions, walls and the Grid in grey.
Any suggestions?
Thanks in advance
RDAOU
@Anonymous
It is only available in the type properties of the Grid type...ANd what is in your image seem like LW 1 for the scale of your view...change scale and it will look thinner
Thanks for the answer. I could search endlessly and never find them in the OS
As for the lineweight itself, the view scale is not the problem. In that image you can see that the projection of the mullions are thinner than the Grid, which means the Grid is in o a thicker Lineweight. This is also the printing scale, I can't change that.
Any other sugestions?
RDAOU
@Anonymous
The thickness of LW 1 differs between Grids and Mullions...where are you checking for LW thicknesses
  • Mullions fall under Model elements
  • Grids fall under annotations
See Giff below...both are LW 1 ... Grid is thicker...Adjust the LW settings and they look the same at my end
Well, that makes the trick!
Thanks!
