can't find drawing in view
yoiyoi
yoiyoi
if i can't't find one of my plan views in the drawing area . hat should i look for after checking  view range and visibility graphics, i can see first and second floor plans but can't get attic or foundation plans to display.
what else should i be checking
jvpantin2
There is nothing visible in view or you can't find them in the project brower? There are two different things. Is curious that default levels views work but attic and basement don't. Check view range again, to avoid mistakes is recommended to use always associated level for all parameters: cut plane, base and top. Also try with these options:
- Check for view underlay in properties palette,
- Check if a view template is applied and controlling view range (uncheck and reset view range in case of)
- Select view in project browser, go to properties palette, check/uncheck crop view and zoom in/out in work space.
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
yoiyoi
thanks, that was helpful
