Revit 2023 .1: An odd behavior I can't seem to work around. If I "edit profile" of a wall or floor, the command that ends and saves the edited profile cannot be found. Where is the "finished" clik-box? Where is it hiding? It seems to be set right be shutting down revit and restarting.
The "edit profile command is grayed out, not accessible, nor are any of the menu's accessible during or after the edit. =<esc> doest help to stop the edit-profile session https://drive.google.com/file/d/1H9YtYHyuaDT00scou_gqsR7yas0RqnOj/view?usp=drivesdk
Sure enough (just tried it) if I close the revit project and re-open, the Mode check box re-appears.
https://drive.google.com/file/d/1m7cGDBGgvVHS45lDSCBkQFDz3hrg-uMd/view?usp=drivesdk
