Can't end EDIT PROFILE
steve
steve
Revit 2023 .1:   An odd behavior I can't seem to work around.   If I "edit profile" of a wall or floor, the command that ends and saves the edited profile cannot be found.    Where is the "finished" clik-box?   Where is it hiding?     It seems to be set right be shutting down revit and restarting.
The "edit profile command is grayed out, not accessible, nor are any of the menu's accessible during or after the edit.  =<esc> doest help to stop the edit-profile session https://drive.google.com/file/d/1H9YtYHyuaDT00scou_gqsR7yas0RqnOj/view?usp=drivesdk
Sure enough (just tried it) if I close the revit project and re-open, the Mode check box re-appears.
https://drive.google.com/file/d/1m7cGDBGgvVHS45lDSCBkQFDz3hrg-uMd/view?usp=drivesdk
Create a keyboard shortcut for Finish Editing (choose the right one among many), and use it when this happens.
handjonathan
Hi @Anonymous
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
