Can't edit railings in Multi level stairs
roscopeco2000
Message 1 of 11
roscopeco2000
Hello Guys i am attempting to create some muti level stairs with bad results the first flight has strange first tread. So i went for a stairs by sketch version but the striings and railings are going wacky. Also i tried using the autolanding tool  i cant seem to edit the railings so they don't go over the mouth of the stairs.any help??
Replies (10)
Message 2 of 11
Hello @roscopeco2000
Railing issue will be solved if you select your railing and (pick a new host ) and select the stair which you want to fit your railing on as shown in screenshotUntitled.pngs.pngdw.png
Message 3 of 11
Viveka_CD
Hi @roscopeco2000
Did the solution by @Anonymous help resolve your issue?
Please see HERE for more information on multistory stairs and how to Modify a Multistory Stair
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.Kudos welcome.
Thank you.
Message 4 of 11
roscopeco2000
Ok thanks but how to do I connect railings up?
Message 5 of 11
@roscopeco2000
I would draw the railing by picking host, the delete one half it.  Repeat and delete the other half.
Message 6 of 11
Sahay_R
Also - when you sketch for the railing - don't sketch - pick the lines instead.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 7 of 11
roscopeco2000
Ok but can I do this for multiple stair cases, the problem is I create a stair case and one landing, but when I come to add a extra staircase the railing is then wrong. Should I be drawing all landings and all stair cases then draw railings in one go? This way it would all be connected up nice?
Message 8 of 11
Normally you just need to do it right for one stair then it will repeat for all of them and they are still right.  Can you share the file?
Message 9 of 11
Sahay_R
Which version of Revit are you in? 2018 gives great tools for multistoried stairs.
Can you share your stair so that a solution minus guesswork can be offered?
Rina Sahay
Message 10 of 11
Viveka_CD
@roscopeco2000 check out the advanced Revit 2018 feature for railings and stairs at this link HERE as suggested by @Sahay_R
Message 11 of 11
pushenergy
see attached mate , i got abit further but i had a host of problems. Strings displaying wrong on bespoke stair case, the 2 upper landings should be 1640mm apart but when i added a straight run staircase it wouldn't bridge the gap i guess due to preset riser height?? i've had a real pain with this ive only ever used the preset stairs before so going from that to this was a headache to say the least...
