Can't edit Pad
Can't edit Pad
info
Message 1 of 11
Can't edit Pad
info
I've created a new pad.
But something weird is happening. I can't select any pads to edit boundary. (See attached).
Also - when I 'Hide Category' for Pads - some disappear others don't. I've checked phases also.
In image I've switched everything off except pads.
Replies (10)
Message 2 of 11
rxi.gg
Edit: solved in post below
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Message 3 of 11
info
I'm actually not selecting the Pads but the toposurface beneath it.
I can see & select Pads in 3D view, but I can't see or select some of them in plan view.
for some reason.
But I've created two sets of identical pads to go with the toposurface(s). i.e.
One set of pads & topo for exist & another set for new construc phases.
Otherwise from experience the pads get tangled up between the different toposurface phases.
Maybe that has something to do with it?
Message 4 of 11
rxi.gg
Solved! you have to show the category emplacement (not sure if the translation is good... emplacement, site, emplacement, siting...)
Message 5 of 11
info
I'm using 2020
Message 6 of 11
rxi.gg
Message 7 of 11
info
Solved it!  -
View range - the other pads were 10mm lower - that's why I couldn't see them in Plan ....
Message 8 of 11
info
Thank-you for your post!.
Message 9 of 11
rxi.gg
@info You mark as solution your own answer! 😉
Message 10 of 11
Use Tab to cycle between topo and pad when selecting. Or do a cross window selection, then filter out topo.
Message 11 of 11
rxi.gg
hi @info I think you mark as solution the wrong post. Can you check it for if someonte in the community in the future will have the same problem? Thanks!
