Post the file.
the family was saved as a family template (.rft) with the person and then used to create the actual family (.rfa).
Once an object is saved within a template, it cannot be removed later.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
Autodesk Certified Professional
You can certainly modify an rft by changing the extension from rft to rfa, opening rfa, modifying it, saving, closing and changing extension back to rft.
I've noticed that in some families that have been changed to a template extension and back that some elements will not let us delete them anymore. It's usually reference planes that are affected (and related dimensions). I don't think it is a good idea to use the extension "trick" on families to make them family templates because you might find it impossible to make some changes to it in the future.
Hard to say about this family without having a copy of it to see ourselves.
Steve Stafford
Family file
Select the driver uncheck Visible. 😉
...or put him inside the bus. That's probably where he's going. Help him out.
